Help with GPU and CPU
Solved by filpo,
6 minutes ago, Valancey said:I have a GTX 1080 right now and a I7-9700k, and feel like i need to upgrade my GPU. So I want to get one that makes me safe for a couple years down the line, I was thinking of getting the 4070 TI, but people say my CPU will bottleneck it. I can't upgrade my CPU as my motherboard does not support it and I don't have enough money to upgrade my whole pc. Any help?
whats your budget? If its 800 bucks (price of a 4070 ti) Might be better to upgrade your cpu and mobo before you get a new gpu
For example, keep your ram and go for a 5800x3d and a b550 tomahawk. Good upgrade for 500 bucks and then save up a little and get the 6800 xt or 6950 xt (or the 4070 ti if you don't like amd)
