Help me chose a GPU, please
Solved by GTC,
I wouldn't bother with a 30 series card, you can get the standard 4070 for the same price or less ($600) and it will outperform all the 30 series cards. The 40 series will also be much better than the 30 series for streaming due to AV1 encoding. If you don't use RT and you want as much FPS per $ than the 7900 XT/X is probably the way to go.
1
Playgb2 ·
Posted in Troubleshooting1 -
1
1
5
kasdashd ·
4
6
play_circle_filled
Latest From ShortCircuit:
