I found a nice, working gpu water cooler if like to get for my gpu, however I do not know much besides the fact I need like a plate cover for my gpu to be able to use it. I have an amd Radeon rx 580 8gb otc black edition. Can anyone with experience help me find a cover plate for it if there’s any? I’m not a huge spender tho so I don’t mind the cheaper options as long as it won’t break my gpu
https://linustechtips.com/topic/1500275-gpu-water-cooling/
Hang on... are you trying to watercool a RX 580? I very much advise against that. The performance unlift will be imperceptable.
I might be experienced, but I'm human and I do make mistakes. Trust but Verify! I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need. Expand this signature for common PC building advice, a short bio and a list of my components.
Common build advice:
1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticeably improve performance past 240mm and don't improve at all past 360mm. 9) RTFM.
Useful Websites:
https://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
Bio:
He/Him - I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 4 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). Aside from computers, I also dabble in modding/homebrew retro consoles, support Southampton FC, and enjoy Scuba Diving and Skiing.
Fun Facts
1) When I was 3 years old my favourite toy was a scientific calculator. 2) My father is a British Champion ploughman in the Vintage Hydraulic Class. 3) On Speedrun.com, I'm the world record holder for the Dream Bobsleigh event on Mario & Sonic at the Olympic Winter Games 2010.
My Favourite Games: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii, Balatro
My Computers: Primary: My main gaming rig - https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C Second: Hosts Discord bots as well as a Minecraft and Ark server, and also serves as a reinforcement learning sand box - https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P NAS: TrueNAS Scale NAS hosting SMB shares, DDNS updater, pi-hole, and a Jellyfin server - https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C Foldatron: My folding@home and BOINC rig (partially donated to me by Folding Team Leader GOTSpectrum) - Mobile: Mini-ITX gaming rig for when I'm away from home -
https://linustechtips.com/topic/1500275-gpu-water-cooling/#findComment-15888712
Yes, and amd Radeon rx 580 8gb otc black edition, only since it heats up often and I don’t like hearing the noise in the bg
https://linustechtips.com/topic/1500275-gpu-water-cooling/#findComment-15888714
Have you tried cleaning the card? Repaste it maybe? what are the temps?
My Rig: CPU : 10700K | RAM : Trident Z Neo 3600Mhz c16 32G (4x8) | CPU cooler : NHD15 | GPU : ASUS ProArt 4070 | PSU : Corsair RM850 (black label) | CASE : Corsair 5000D Airflow | Storage : Samsung 970 evo 1TB, WD Black 1TB, Samsung evo 850 Sata SSD | Casefans : Lian Li Unifan SL120 7X|
MOUSE : G Pro Wireless X superlight | Keyboard : Keychron C1- Pro-H1 Gateron Milky Reds
https://linustechtips.com/topic/1500275-gpu-water-cooling/#findComment-15888728
I highly doubt it’s dirty since it’s a refurbished product, but it may need more thermal paste. I haven’t checked. The the temps usually lift up whenever I use for example: fortnite, they go around 73-82 with full fan power. even if my frames don’t drop. I usually get 70-80 fps with the settings I have for my preference, they aren’t over kill though, heavy stuff is disabled and other setting are usually on med to med high ish. I might check the paste later today once I’m back from school.
https://linustechtips.com/topic/1500275-gpu-water-cooling/#findComment-15888733
What did you get ? I mean a GPU watercooling is a standard rad, tubing, and then a waterblock  and a pump somewhere
Without a block it's nothing else than a bunch of watercooling parts ... and buying  ablock for a RX580 is a really bad idea (if ever they exist)
https://linustechtips.com/topic/1500275-gpu-water-cooling/#findComment-15888737
How come it’s a bad idea?
https://linustechtips.com/topic/1500275-gpu-water-cooling/#findComment-15888744
The waterblock and pump will cost you more than a better GPU ...
https://linustechtips.com/topic/1500275-gpu-water-cooling/#findComment-15888747
No, I found a reseller who I am good friends with, he has a working one that comes with everything, all I need is the plate to actually be able to assemble it if I’m correct.
https://linustechtips.com/topic/1500275-gpu-water-cooling/#findComment-15888754
Still I didn't get what "plate" you're talking about, that's why I asked what did (or will) you get exactly ...
https://linustechtips.com/topic/1500275-gpu-water-cooling/#findComment-15888762
2 minutes ago, PureGlee said:
I think I’m just rambling, idk. Like I said idk much abt this. I’ll att a picture of what it looks like
And yes I know it doesn’t seem to have fans for it, I’ve bought some that were originally gonna go on my case before I found this. My case fan space is two 120mm vents on top
https://linustechtips.com/topic/1500275-gpu-water-cooling/#findComment-15888773
So it's a pump block and a rad .
Rad design is ... original 😛 , idk where you can install it without sawing off the "appendages" on the sides 😄
So indeed you need a RX580 plate, there are some on Aliexpress but it's $100+...that's more than the card value on Ebay...
https://linustechtips.com/topic/1500275-gpu-water-cooling/#findComment-15888784
True that, is there a specific model I should be looking for?
https://linustechtips.com/topic/1500275-gpu-water-cooling/#findComment-15888789
It looks like an HG10, if my research serves me correctly. Those have their own blower style cold plate designed to cool its VRMs, if youre using this youre going to need that too and they havent made a cold plate for it since R9 290x.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1500275-gpu-water-cooling/#findComment-15888811
Think you could find links?
https://linustechtips.com/topic/1500275-gpu-water-cooling/#findComment-15888816
It's aliexpress so be careful, and it'll be only some copies of old past designs, no brand make this anymore afaik (if ever they did)
IMO you'd better off using the money in a new GPU, a RX6600 is near double RX580 perf for $220...
https://linustechtips.com/topic/1500275-gpu-water-cooling/#findComment-15888832
I guess youre bad at inferring information. There's no cold plate for this thing, youre going to have to machine it yourself, using an h100i mounting. But yeah, unless if you have your own neighbor with a CNC like Linus did back in his old house, it wont be worthwhile unless youre doing it for the novelty in which case knock yourself out.
https://linustechtips.com/topic/1500275-gpu-water-cooling/#findComment-15888838
