Help upgrading PC??
Solved by PcBeExpensive,
5 minutes ago, lowlowlopez said:My concern for the MOBO is it would adapt well to the new GPU, and in regards to de PSU I thought about getting a 1000W just to be safe or even an 800W.
In regards with the temp ill have to get to you cause I had to delete the asus crate apps cause they were causing some bottleneking to my Ram and I thought i didnt need it, (sike) let me see if I could re-install it or another app
why would it not adapt to the gpu? As long as it has a PCIE slot your fine. Don't buy a 3080 for playing in 1080p a 3070 LHR would be sufficient enough. you should only need a 700W psu to run that but get a 750W one so you have some headrom to overclock and upgrade you cpu if you want to.
