Hi guys, hope you all doin well 🙂
well i have a problem with my script on mikrotik router, the meaning of script is to go Web page copy the body of the web ( which contains only ip addresses ) and create .txt file in mikrotik files after that add ip addresses inside that .txt file into address list. My script did copy of the web body paste into .txt document but it can't add into address list , i figured out why because in body of that web the ip addresses is typed vertical and without commas, well i wanted to add some code on my script but it does not worked at all,
could someone help me with that? or provide a script maybe or other solution to fix this 😞
this is the code
:local url "webpagedotcom"
:local list "addresslist"
:if ([:len [/ip firewall address-list find list=$list]] = 0) do={
  /ip firewall address-list add list=$list
/tool fetch url=$url mode=http dst-path=ip-list.txt
:local ips [/file get ip-list.txt contents]
:local iparray [:toarray [:resolve $ips]]
:local ipregex "([0-9]{1,3}.){3}[0-9]{1,3}"
:local ipstring ""
:foreach ip in=$iparray do={
  :if ([$ip] ~ $ipregex) do={
    :set ipstring "$ipstring$ip,"
:if ($ipstring != "") do={
  :set ipstring [:pick $ipstring 0 ([:len $ipstring]-1)]
  /ip firewall address-list set [find list=$list] address=$ipstring
/file remove ip-list.txt
Akinator V2 is here :D
https://linustechtips.com/topic/1499047-mikrotik-script-problem/
