I'm sure others have ran into this issue. I am just unable to pinpoint where the problem lies.
My Specs:
Strix Z590-A Gaming Wifi
MSI Gaming X 3060ti
For some reason when booting using display port, my system will show no display at all until I reach Windows. It completely bypasses the post/bios splash-screen and the VGA light remains on on the motherboard. Everything functions properly when in Windows and I have absolutely no issues playing games. However, all of this is avoided when using HDMI. I have found that when I enable CSM in the Bios (when I'm able to boot into it) I have no issues on display port. The GPU had no issues at all in another system so I know the GPU should be fine.
I have flashed the latest BIOS on the MB, and checked that my GPU has the latest display port firmware. Neither have worked. I figured I'd turn to you all to see if I can find a fix!
https://linustechtips.com/topic/1498763-booting-issue/
