help troubleshooting
Go to solution Solved by filpo,
9 minutes ago, DragonCrystal2 said:
hi, I'm new here and I need help troubleshooting my pc, idk why but my pc looks a lot worse them my ps5, and I'm not sure why my specs are, I also play on a 4k tv lg webos um6910puc, idk if I'm posting this from right lol.
CPU Cooler:
RGB Tower Cooler
Motherboard:
B550
Primary Hard Drive:
1TB NVMe SSD
Power Supply:
650 Watt 80 Plus Gold
Networking:
802.11 ac
Operating System:
Windows 10 Home, 64-bit
this isn't troubleshooting but pcs are normally more expensive than consoles because consoles use a simpler architecture and also most computer hardware has to be comaptible with other hardware. If you want good frames with 1440p gaming then try getting a better gpu like the rx 6800 ASRock Radeon RX 6800 Phantom Gaming D Gaming Graphics Card with 16GB GDDR6, AMD RDNA 2 (RX6800 PGD 16GO) - Newegg.com or the 7900 xt
XFX Speedster MERC310 AMD Radeon™ RX 7900XT Gaming Graphics Card 20GB GDDR6, AMD RDNA™ 3(RX-79TMERCU9) : Amazon.it: Computing
hi, I'm new here and I need help troubleshooting my pc, idk why but my pc looks a lot worse them my ps5, it's blurry and has bad lighting it's always to bright or to dark, and all edges have a small white look to them likes its's to sharp and as a hard time rendering, and I'm not sure why, I also play on a 4k tv lg webos um6910puc, idk if I'm posting this from right lol, but my pc specs are.
CPU Cooler:
RGB Tower Cooler
Motherboard:
asrock B550 bios are updated
Primary Hard Drive:
1TB NVMe SSD
Power Supply:
Networking:
802.11 ac
Operating System:
https://linustechtips.com/topic/1498733-help-troubleshooting/
CPU Cooler:
RGB Tower Cooler
Motherboard:
B550
Primary Hard Drive:
1TB NVMe SSD
Power Supply:
Networking:
802.11 ac
Operating System:
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1498733-help-troubleshooting/#findComment-15878104
13 minutes ago, DragonCrystal2 said:
RGB Tower Cooler
also what specifically? a good tower cooler would be the thermalright peerless assassin 120 se if you have bad temps on your cpu
Total: £1040.95
https://linustechtips.com/topic/1498733-help-troubleshooting/#findComment-15878106
