using DDU need help
Go to solution Solved by C2dan88,
  1. Download new driver before hand.
  2. Disconnect from internet and reboot into safe mode (Shift Restart > Advanced Options).
  3. Run DDU.
  4. Reboot
  5. Install downloaded driver
  6. Reconnect Internet.
Hi I have 2 questions
I wanna use ddu to perform a clean install of my gpu driver. I watched a video on Jayz's channel Jayztwocents) where he recommends to disable the windows feature that allows windows to install a basic display driver just to boot up windows. My question is if I did that how will I get a signal after using ddu? it doesnt showcase it in his video (i can link it if needed) or is this just overkill and I shouldnt be bothered.
Also, the last time I updated my amd gpu driver (few months ago without using ddu) I ran into a problem where the pc boots but there is no screen, its just black, and after looking it up apparently its a common problem, is there a way around this issue?
thanks
https://linustechtips.com/topic/1498066-using-ddu-need-help/
