Help
Go to solution Solved by Birblover12,
Do you have an I-GPU (your CPU's integrated graphics)? Are you able to plug your monitor into it if you have it? Have you tried a different cable? Does the rest of the system power on (fans spin, power LED lights up, RGB turns on, etc.)?
Keep in mind that I am sometimes wrong, so please correct me if you believe this is the case!
"The Nvidia Geforce RTX 3050 is brutally underrated"
https://linustechtips.com/topic/1498008-help/#findComment-15872747
yes thanks
https://linustechtips.com/topic/1498008-help/#findComment-15872749
