Budget (including currency): 1000usd
Country: us
Games, programs or workloads that it will be used for: gaming/blender
Other details:
I know it's above my budget but I'll be buying the GPU used to get it below my budget, also would like to have overclocking headroom for at least CPU.
https://pcpartpicker.com/list/j8yTQ6
Is this good for budget? I want something powerful and cheap.
https://linustechtips.com/topic/1497949-building-pc/
Country: us
Other details:
https://pcpartpicker.com/list/wR6Fv3. I would go for a 5600x, its cheaper and still a great CPU and would work really well with a 3070.
My First PC
CPU: Ryzen 5 5600x
Cooler: Asus TUF Gaming LC240
Motherboard: Asus ROG Strix B550-f gaming
RAM: 4x8 GB Corsair Vengeance RS (3200 MHz, CL16)
Storage: 1tb Samsung 980 Pro
Graphics Card: Asus Dual RTX 2060 OC
Case: Deepcool Matrexx 50
Power Supply: Corsair RM650x
Headset: Razer Blackshark V2
Keyboard: Corsair K70 Pro Mini (Speed Silver switches)
Mouse: Razer Viper Mini
Only changes I have made is I sold the 2060 for $235 AUD and bought a Powercolor Red Devil 6700 XT for $400 second hand (it was barely used, think I scored a deal on Ebay with that).
I love Photography (Using a Canon 60D)
Love F1, my favourite team is Ferrari and my favourite driver is Leclerc
https://linustechtips.com/topic/1497949-building-pc/#findComment-15872194
Seems reasonable enough I guess, but if you don't mind me asking, why did you decide to go DDR4 instead of DDR5? I know future proofing isn't a thing, but it does seem like it would be better for you to get on that platform now, where you can buy more RAM if you need it for Blender.
https://linustechtips.com/topic/1497949-building-pc/#findComment-15872219
I'm know youre right, and honestly might do that, but in my head I don't want less cores even if it would be fine, although that price difference is very attractive
https://linustechtips.com/topic/1497949-building-pc/#findComment-15872238
Ddr4 because it was cheap, I didn't really look for anything else, just sorted by price, good thing to keep in mind though.
Athough I'm not sure the performance difference between the two, I would have to check as I don't feel it to be too important.
https://linustechtips.com/topic/1497949-building-pc/#findComment-15872246
I dont know who started the trend of using used 3070 on everything when used RX 6700XT can be had for 50-25$ less, and RTX 2080 Super exists at similar price range (or lower if you do your due diligence and battle ebay snipes) and similar performance but are less plagued with the transient power, so i could straight faced recommend to run 650W on it. Cross shop with those, but if you do frequently used blender, you can easily just throw out the 6700XT from contention.
Also, you really should forget 12th and 13th gen overclock, theyre given such an insanely huge power budget that you can legitimately run it dead stock and itll reach damn close to its overclocking speed anyway. Grab the biggest cooler you can and run it to the sunset.
PCPartPicker Part List
CPU: Intel Core i5-13500 2.5 GHz 14-Core Processor  ($249.98 @ Newegg)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($33.90 @ Amazon)
Motherboard: ASRock B660 Pro RS ATX LGA1700 Motherboard  ($128.99 @ Newegg)
Memory: G.Skill Sniper X 32 GB (2 x 16 GB) DDR4-3000 CL16 Memory  ($59.99 @ Newegg)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($59.99 @ Adorama)
Video Card: Gigabyte GAMING OC Rev 2.0 GeForce RTX 3070 LHR 8 GB Video Card  ($350.00)
Case: Fractal Design Focus 2 RGB ATX Mid Tower Case  ($75.98 @ Newegg)
Power Supply: Enermax Revolution D.F. 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Total: $1048.82
Generated by PCPartPicker 2023-03-31 17:46 EDT-0400
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1497949-building-pc/#findComment-15872337
