Stuck m.2 screw
By
Jing_Jan
in Troubleshooting
in Troubleshooting
Solved by Jing_Jan,
On 3/29/2023 at 5:19 PM, Poinkachu said:That screw is totally stripped, most likely you won't be able to unscrew it using a screwdriver.
Use a plier to unscrew the screw
Took some time but got it out. Thanks for the help.
voltigeurramon ·
Posted in Troubleshooting1 -
1
Vibora ·
Posted in New Builds and Planning4 -
4
3
Doctah ·
Posted in Peripherals3 -
8
michaelb198 ·
Posted in Peripherals2
