Hey guys,
I'm wanting some advice please.
I'm running a 9700k in a none overclockable board and had a 16gb set of Dominator DDR4 LPX C16 rated at 2666 which ran as advertised using XMP, I recently added another 16gb of Dominator DDR4 LPX C16 but rated at 3200 as it was all I could source.
The RAM runs absolutely fine at stock but if I try and activate XMP at 2666 it just refuses to post.
I've always been under the understanding that if you got 2 different speeds of RAM they just ran at slowest speed or is that not the case when using XMP.
It's not a major drama as how I see it 32GB at stock is still far superior to 16GB with a slight clock to 2666 but just wondered if I'm doing something wrong or if there's an easy fix I'm missing.
Thanks
https://linustechtips.com/topic/1496494-memory-help-please/
23 hours ago, _Omega_ said:
can you take a look which voltages are listed on the kits?
Where would I find the voltages?
I found this information on their website
2666:
Tested Latency 16-18-18-35
Tested Voltage 1.2V
Tested Speed 2666
SPD Latency 15-15-15-36
SPD Speed 2133MHz
SPD Voltage 1.2V
Speed Rating PC4-21300 (2666MHz)
3200:
Tested Latency 16-18-18-36
Tested Voltage 1.35V
Tested Speed 3200
SPD Speed 2133MHz
SPD Voltage 1.2V
Speed Rating PC4-25600 (3200MHz)
https://linustechtips.com/topic/1496494-memory-help-please/#findComment-15862667
