This problem is weird all my game launchers like steam, epic games and battle net say that i have no internet connection.
My browser works just fine.
I cant even do a windows update cause it says i have no internet also it says in my taskbar that im connect (ethernet)
how do i fix this problem
https://linustechtips.com/topic/1495994-internet-problem/
Try changing the DNS server that your machine is using. Windows does its own pings in the background to see if you have an internet connection. I've run into the same issue as you in the past, where windows said no internet (when I do) where the browser works fine but other stuff doesn't.
It's entirely possible whatever servers they are trying to reach can't be connected to because it's not getting the correct information from DNS
Also the good old method of
turn it off and on again
sometimes fixes it
https://linustechtips.com/topic/1495994-internet-problem/#findComment-15856739
Sounds like DNS issue as my computer does it sometimes, resulting in my video calls being interrupted and reconnected in several seconds.
Normally the DNS config above would help. I also tried Disabling the Ethernet / Wifi port via Network Connections (search via Windows taskbar) and right-click on those icons to Disable before Enabling them again after a minute. It did help a bit.
I hope there will be better ways to help you with this issue.
https://linustechtips.com/topic/1495994-internet-problem/#findComment-15856884
sometimes fixes it
try it didnt work
https://linustechtips.com/topic/1495994-internet-problem/#findComment-15856927
