Microphone Recommendation
This setup is very similar to what was posted in this topic a week or so ago. (See spoiler)
I'd say for a "nice sounding" microphone, you can't go wrong with the quality of Shure products. The main thing to keep in mind is you may end up needing to get an in-line amplifier if you'd like to boost the audio levels a bit more. I Shure did with the SM7B, but that mic is known for this. I'm not as familiar with the MV7x, so I'd say if that's what you've narrowed your choice down to after doing a bit of independent research, give it a shot and see if you like it. If it's too quiet, get an in-line pre amp like the fethead or cloudlifter or other similar product. If you still don't like it, ordering from somewhere like Amazon would be preferred where you have a grace period to return the items and test something else out.
It sounds like you have a good chunk of the equipment, it'll just take some getting used to the very close mic placement that's required for dynamic microphones to pick up your voice properly. So ensure you're comfortable and have the space to get the mic as close to your face as possible, otherwise I would not be looking for dynamic microphones.
