I know 60 is usually alright, but its not under load. Its just downloading a game from steam. i5 750 1st gen. I have more fans installed in the case than a PC from this era usually would.image.thumb.jpg.55de6741dd7d380438bec56efdd4dc56.jpg
they peak around 62 every so often for a few secs. I just worry how it will be under load.
https://linustechtips.com/topic/1495604-cpu-temps-normal/
Is this during idle and what cpu cooler do you have so we can have a bit more to go on. Also is this at boot or after being in the os for a long time and just monitoring the temps
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1495604-cpu-temps-normal/#findComment-15853044
Its not under load its just been downloading for the past 40 mins. Intel stock cooler.
https://linustechtips.com/topic/1495604-cpu-temps-normal/#findComment-15853046
yes its normal. You are using a pretty damn old CPU, Downloading a game thats pretty large will be it under a pretty huge load.
https://linustechtips.com/topic/1495604-cpu-temps-normal/#findComment-15853049
Downloading games does use cpu usage. Even games on a slow network (like 6mbps) still takes like 10 percent of my 5600 and it’s hurting your temps even more that it’s being cooled by a stock cooler
Total: £1040.95
https://linustechtips.com/topic/1495604-cpu-temps-normal/#findComment-15853050
