Is it possible to use another dGPU as NVIDIA P106-100 display output?
Solved by naz.rin,
On 6/8/2023 at 7:44 PM, unamed666 said:Can u tell me if its work? I really want to know
yes it works! but you can only install 472.12 driver since that the only latest one that can support kepler and maxwell at the same time. and you need to modify the display GPU as power efficient GPU. You can search on google how to do that by searching "enable mshybrid registry"
Featured Topics
mr.kaiju ·
Posted in Troubleshooting0 -
LstpersonalOF ·
Posted in Tech News5 -
Ehrix ·
Posted in Storage Devices8 -
1
1
VemmyPcs ·
1
4
2
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
