3 minutes ago, emosun said:
your plan should work fine having the top as exhaust.
though if the fans speeds arent very fast then that could explain bad thermals , basically if the pcs fans are set high enough then the orientation starts to matter a lot less.
No currently my top ones are intake and the rear one is exhaust. I plan to change the top one as exhaust after i buy 3 fans for the front.
https://linustechtips.com/topic/1495058-fan-configuration/#findComment-15849295
28 minutes ago, Mukundkannan said:
Do you mean i should make it as exhaust before i get the 3 fans for my intake ?
you can do it when you get your fans or before it really doesn't matter.
29 minutes ago, Mukundkannan said:
But wouldn't that create a negative pressure inside the case
negative or positive pressure doesn't really matter if you clean your computer
https://linustechtips.com/topic/1495058-fan-configuration/#findComment-15849349
