On 3/17/2023 at 1:48 AM, circeseye said:
bad cable? bad driver? you have a gpu setting set wrong
only 3 things i can think of
sorry for the late response, i fixed the problem by switching over to DP 1.2 and not 1.4 which i find strange because its the monitors own cable.
https://linustechtips.com/topic/1494535-hdr-disabling-it-self/#findComment-15851285
That is very strange...
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
https://linustechtips.com/topic/1494535-hdr-disabling-it-self/#findComment-15851301
Maybe see if there's a newer firmware available for your monitor
GAMER
Home LAB
Racing SIM
https://linustechtips.com/topic/1494535-hdr-disabling-it-self/#findComment-15852195
i installed that first when i tried to fix screen being black for a few seconds when switching applications(fullscreen like minecraft to chrome). the settings where normal then, no HDR of some sort and it looks like it just switches to HDR or to a different source.
https://linustechtips.com/topic/1494535-hdr-disabling-it-self/#findComment-15852305
