I'm having trouble finding a good internal card reader. I need high speed, high capacity - support at least 32GB cards (even higher capacity would be better). I need support for SD, SDHC, Memory Stick Pro Duo (including 32 GB Memory Stick Pro-HG Duo HX)... I can't hook it up to a usb 3.0 header because my motherboard (Asus z87Pro) only has 1 and it's being used for the two front panel usb 3.0 ports. I don't really need usb 2 and 3 ports on the card reader since my case's front panel has two of each. Write capable would also be nice.  Does anyone have any suggestions?
https://linustechtips.com/topic/149386-internal-multi-card-reader/
What size dimension do you need the card reader in? 5.25in or 3.5in?
Here one: http://bit.ly/1nkypHi
Usable considering that you don't have a spare usb 3.0 header
nzxt aperture m... :)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811992010
How slow will the card reader be if connected to usb 2.0 header? Will it affect the compatibility of high speed high capacity cards? Is there a way to connect it to usb 3.0 in the back of the case, or does it need to be mid board? Would it be better to add a USB 3.0 PCI-E card with an internal header?
Would this work HooToo HT-PC002? http://www.newegg.com/Product/Product.aspx?Item=9SIA1HD0PB5476
with this Atech Flash Technology PRO-77U? http://www.newegg.com/Product/Product.aspx?Item=N82E16817245002
Anyone? Please help. I like the Pro-77u specs. What reliable usb 3.0 pci-e expansion card internal header will work best (windows 8.1 64bit, asus z87 pro motherboard)? I don't really need external ports, just internal header. Maybe one of these would work? http://www.amazon.com/SuperSpeed-Expansion-Motherboard-Connector-Capacitors/dp/B00C3X982S/ref=sr_1_1?ie=UTF8&qid=1399658661&sr=8-1&keywords=pcie+usb+3+internal+header+expansion+card
http://www.amazon.com/Silverstone-Tek-EC01-P-Internal-Connector/dp/B0079XWO4G/ref=sr_1_2?ie=UTF8&qid=1399658661&sr=8-2&keywords=pcie+usb+3+internal+header+expansion+card
http://www.newegg.com/Product/Product.aspx?Item=N82E16815256004
other options?
