Hi all, I used the PS5 controller with my PC. Been working fine. Suddenly it started acting up. I can't be sure if it started ever since I installed DualsenseX.
2 random lights show up on the controller (see attached photo), and the button on the trackpad is registering as pressed all the time. Nothing is stuck underneath. Everything else works fine.
I've tried another PC, a Mac, reset the controller via the reset button at the back. The firmware is up-to-date. What can I do? It's oow
I don't have a PS5. Don't have anyone closeby who has a PS5 either. I went to GameShop to see if i could pair it to thier console but they did not have one on display:/
TIA
https://linustechtips.com/topic/1493544-ps5-controller-issue/
On 3/15/2023 at 3:03 PM, Snak3s said:
Any help would be appreciated
TIA
I found something on the official playstation website (sorry for the long response) link to website https://www.playstation.com/en-gb/support/hardware/ps5-ps4-power-indicator-lights/
Reinstall system software: https://www.playstation.com/en-gb/support/hardware/reinstall-playstation-system-software-safe-mode/
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1493544-ps5-controller-issue/#findComment-15846748
Hi, I appreciate the attempt to help, sadly your article is about the actual system, not the controller. Thanks nonetheless
https://linustechtips.com/topic/1493544-ps5-controller-issue/#findComment-15846787
  • 2 weeks later...
  • 3 months later...
Update: in case it helps anyone who ever faces this issue, NO ONE has ever reported/faced this issue on YouTube and Reddit.
Basically, I opened the controller and cleaned the contacts of the ribbon cables The touchpad cable had a weird substance / dirt on it which i think was the culprit. Weird as it was never opened. The issue went away post this
https://linustechtips.com/topic/1493544-ps5-controller-issue/#findComment-16066141
