So basically for the last few month my pc has been acting strange rebooting, so i have been trying to fix it it software with no success so i bought a new psu hoping it would fix my issue spoiler it didn’t. In the event viewer it says kernel power 41(63) and i have attached some more info which the error states. Also i attached few other errors from the event viewer.
+ System
- EventData
    BugcheckCode 402
    BugcheckParameter1 0xffffb58893330080
    BugcheckParameter2 0x0
    BugcheckParameter3 0x0
    BugcheckParameter4 0x0
    SleepInProgress 0
    PowerButtonTimestamp 0
    BootAppStatus 0
    Checkpoint 0
    ConnectedStandbyInProgress false
    SystemSleepTransitionsToOn 0
    CsEntryScenarioInstanceId 0
    BugcheckInfoFromEFI true
    CheckpointStatus 0
    CsEntryScenarioInstanceIdV2 0
LongPowerButtonPressDetected
false
https://linustechtips.com/topic/1493397-kernel-power-41-random-restarts/
1. lets start with what hardware do you use?
2. have you changed anything before those crashes started?
Gigabyte X570 Aorus Elite,  Ryzen 9 3900x, Dark Rock Pro 4, 16 GB Crucial Ballistix  RGB 3600 MHz CL16 RAM, RTX 3080 TI FE Watercooled, 6 Case Fans,  Fractal Design Meshify S2
You are awesome, stay safe and healthy.
a
CPU: Ryzen 5 3600
Mobo: Asus B550a
GPU: Gigabyte RTX 3060ti
RAM: G.Skill Trident Z 3200 Mhz
PSU: EVGA SuperNova 650 GA
SSD: Samsung 250GB m.2
HDD: Seagate BareaCuda 2TB
I didn't do anything they just started appearing out of the blue
Bios update, after it is done reload default settings and report back
you also replacced your PSU hmmm
okay, hmmm right now I am fishing in the dark.
could you post a picture of your pc inside, wanna see if everything is plugged in.
something else you could try is
power plan, chance it to high performance
