PC SPEC
gigabyte b365m ds3h - Motherboard
2060 super
i5 9600k
2 8 sticks off ddr5 ram
No OC'S on the gpu or cpu
I have had people tell me to overclock the 9600k an that im not using half its power but tbh ive overclocked gpus in the past but never cpu's I dont wanna mess something up or shorten the life span of the cpu just for a small amount of performance boost also I don't have a extreme cooling system in my pc I literally just have the basic intel cooler for my cpu..
I mostly just stream games such as val,rust, apex legends and some other small indie games here and there and I honestly don't have any issues with doing that my fps stays decently high and its playable an the stream doesn't look like a potato just wanting some ideas to make the pc run smoother under heavy loads without breaking the bank!
https://linustechtips.com/topic/1492715-help-upgrading-my-pc/
16 minutes ago, nodah said:
PC SPEC
2060 super
i5 9600k
Get more ram and maybe upgrade the CPU cooler. Also you got DDR4. I would recommend 2x16gb 2666mhz. If you want a good cheap kit I can recommend G.skill Aegis.
Also no worries about overclocking as it's not supported by your motherboard. Even XMP isn't supported, so 2666mhz would be the highest speed for ram.
Height for the CPU cooler suggested below is 154mm, and check clearance before getting any CPU cooler.
PCPartPicker Part List: https://pcpartpicker.com/list/YWhTLs
CPU Cooler: ID-COOLING SE-224-XT Basic 76.16 CFM CPU Cooler  ($26.99 @ Amazon)
Memory: G.Skill Aegis 32 GB (2 x 16 GB) DDR4-2666 CL19 Memory  ($61.99 @ Newegg)
Total: $88.98
Generated by PCPartPicker 2023-03-08 06:18 EST-0500
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1492715-help-upgrading-my-pc/#findComment-15833231
Total: $88.98
thank u for clarifying my motherboard doesn't support xmp.. and sorry for the typo i didnt catch me putting ddr5 lol i got 2 8bg sticks of ddr4-ram 3200mhz corsair vengeance should i just get 2 more of those stick an slap them in or would it be better to look into possibly getting 2 16gb sticks instead... also I would like to upgrade my motherboard I just dont want to by something that the same or worse then the one I have right now I literally know nothing about motherboards and that explains why i got 3200mhz instead of 2666 when it came to ram..
https://linustechtips.com/topic/1492715-help-upgrading-my-pc/#findComment-15833254
You could get another of those kits and it'll work alright. In reality they run at stock speeds, unless you set this is bios. So 2133mhz. If you want to upgrade the motherboard, you should upgrade the CPU too imo.
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1492715-help-upgrading-my-pc/#findComment-15833260
56 minutes ago, nodah said:
PC SPEC
2060 super
i5 9600k
What's the budget?
To be blunt, the CPU/motherbaord is what I'd change first. 6 cores without Hyperthreading on an old architecture probably causes you stutters when someone is shooting at you in APEX. A new CPU would solve that.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1492715-help-upgrading-my-pc/#findComment-15833262
On 3/8/2023 at 7:01 AM, 191x7 said:
What's the budget?
sorry for the late reply but honestly I would like to keep it under 400$ to 350$ for the MB an CPU or around that range... tbh I built this pc build during the pandemic as like a extreme budget sleeper build and well it didnt work as plan well kinda for 690$ it worked. the only thing ive upgraded is the gpu i had the 1650 super but honestly it just wasn't enough for what im trying to do so I went out got a 2060 super an now I feel like I should just finish upgrading everything els if its not extremely expensive.
https://linustechtips.com/topic/1492715-help-upgrading-my-pc/#findComment-15837738
Well, you don't even have to spend that much to see a noticeable improvement.
You can get a Ryzen 5 5600 ($150) or a Ryzen 7 5700X ($250) and pair it with a B550 motherboard from Asus, MSI or Gigabyte. Let's say $150 for the motherboard.
Or, you could go the Intel route, get an i5 12400f or 13400f or such and a B660 or B760 motherboard that accepts your DDR4. You don't have DDR5.
Or, you could increase your budget a bit and get a Ryzen 5 7600 paired with a B650 motherboard and 16GB of DDR5 RAM faster than 5400.
https://linustechtips.com/topic/1492715-help-upgrading-my-pc/#findComment-15838117
1 hour ago, nodah said:
thank u actually very reasonable prices tbh... what would u recommend I go with for the best bang for the buck
Exactly what I mentioned. One of those options.
The Intel one would allow further updates to the CPU while 12th/13th generation is available, for example to an i7 12700k or i7 13700k.
The AMD one with Ryzen 7600 would allow upgrading to a stronger Ryzen 7000, and highly likely an 8000 or 9000 when those come out. AMD promised AM5 is going to be used for a few years for new CPU-s. But that needs DDR5 and thus is pricier.
AM4 Ryzen is a platform with no meaningful upgrades above the 5600 or 5700X; you could get a 5800X3D for slightly better gaming performance or a 5900x/5950x for better productivity and the same gaming.
https://linustechtips.com/topic/1492715-help-upgrading-my-pc/#findComment-15838492
