My pc specs are:
ASRock B650M PG Riptide
Ryzen 57600X
ASRock Challenger RX 6700 XT
2x8 Kingston DDR5 6000MHz
Corsair CX650F RGB
I was tweaking the bios and exited then I was met with and error on the status light indicating the error was on the CPU and RAM. I tried jumping the jumper pins with a screwdriver for 10 sec ---> hours and would still not post. I have reseated the ram from A2 -> A1, B2- B1; only B2; only A2; reseated the CPU and the GPU but still could not post.
https://linustechtips.com/topic/1492138-my-pc-would-not-post/
Just now, StickyPC said:
Unplug your PC from the wall. Take out CMOS battery. Wait 1 min. Put CMOS battery back in and plug in PC, see if it posts.
Looks like you may have touched the overclock settings and put an unstable overclock
There's no visable CMOS battery so I just jump the CMOS jumper. I unplug my pc from the wall everytime.
https://linustechtips.com/topic/1492138-my-pc-would-not-post/#findComment-15829185
11 minutes ago, StickyPC said:
It is strange that there is no cmos battery. Make sure you are shorting the correct 2 pins with something that is conductive. Have you looked for the  cmos under the gpu or above the ram?
I've disassemble everything at one point and no visable CMOS battery, could it be on the back of the board?
https://linustechtips.com/topic/1492138-my-pc-would-not-post/#findComment-15829188
Just now, Remi.Aruni said:
I've disassemble everything at one point and no visable CMOS battery, could it be on the back pf the board?
very possible. Taking out the board though is extremely difficult i will try to find where the cmos battery is on your board.
https://linustechtips.com/topic/1492138-my-pc-would-not-post/#findComment-15829189
3 minutes ago, StickyPC said:
Hi, I have found the solution
Go to pages 35, 49, 50
When shorting the pins make sure that you are using the jumper.
there is also a bios flashback feature
There isn't any jumper included so my solution was using a screwdriver but it did not work. About the BIOS flashback, so basically I just update/downgrade my BIOS?
Idk my BIOS ver.
https://linustechtips.com/topic/1492138-my-pc-would-not-post/#findComment-15829204
Idk my BIOS ver.
yep you update bios i think via flashback make sure you follow instructions
https://linustechtips.com/topic/1492138-my-pc-would-not-post/#findComment-15829218
