Need Upgrade for CPU
Go to solution Solved by DEADPOOLSMOM,
5 minutes ago, MiclTehPicl said:
Budget (including currency): $ U.S. Dollars $ 100 ish
Country: U.S.A.
Games, programs or workloads that it will be used for: Minecraft, Fallout (all of them besides 76),
I have a 1080ti and want to upgrade my CPU from a 3770, and I want to play at 1080p.
There's no meaningful upgrade you could get for $100, sorry. Full system upgrade is in order. You already have the best cpu for that socket
Country: U.S.A.
https://linustechtips.com/topic/1491838-need-upgrade-for-cpu/
Country: U.S.A.
CPU-AMD Ryzen 7 7800X3D GPU- Gigabyte WindForce SFF RTX 5070ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE- 2TB Samsung 990 Pro PCIE4 NVME x2 PSU-Corsair RM1000x Shift COOLING-Lian Li GA II Lite 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-Samsung G61 QD-OLED 1440p 240hz +Gigabyte G24F 1080p 180hz PERIPHERALSVaxee XE-S+Padsmith Crucible Mousepad+Monsgeek M1 V5 TMR+Autonomous ErgoChair+ AUDIO-Audient iD4 Mk II + Rode NTH100
https://linustechtips.com/topic/1491838-need-upgrade-for-cpu/#findComment-15827148
