Hello,
I've just built this PC and for some reason when logging into windows whilst all my start up programs are loading my computer completely freezes up for a second but once its done loading, I can use it again, never really experience this, don't know if its that big of a deal.
When loading programs sometimes it will completely lock up also.
The big issue I'm seeing that I can replicate on the spot is,
For example I'm loading into a game on the loading screen and have a youtube video playing on the other monitor, the FPS of said video will drop to about 15 fps, basically just really low, but once the game loads the video returns to normal fps.
I'm not exactly sure what's going on and dont know what the culprit could be 😞
Any help is appreciated !
Thanks
Mark
https://linustechtips.com/topic/1491494-pc-weird-lag-need-help/
First of all, try updating your drivers, is that doesn't work, try re-seating your RAM and GPU (the CPU can have wrong mounting pressure too if you want to check).
And in the last resort try re-installing the entire operating system to see if the system files were corrupted in the first place.
Expand for PC Specs.
Desktop:
  • CPU: Intel Core i5 9400F
  • GPU: Palit Geforce RTX 3060 LHR 12GB
  • RAM: 16GB 3200MHz DDR4
  • SSD: 240GB Gigabyte NVMe M.2
  • HDD: Seagate BarraCuda, 3,5" - 2TB 7200RPM
  • Case: Zalman ZM-T2 Plus
  • MOBO: Gigabyte B360M-H (rev 1.0)
  • Case Fans: 3x Arctic F12 Silent Black, 120mm, 1x Zalman 80mm silent fan
  • CPU Cooler: ARCTIC Alpine 17
Laptop:
  • Model Name: ASUS X571GD
  • CPU: Intel Core i5 9300H
  • GPU: Nvidia Geforce GTX 1650
  • RAM: 16GB 2400MHz SODIMM
  • SSD: 512GB NVMe M.2
Peripherals:
  • Mouse: Glorious Model O- Wired
  • Keyboard: Hama Urage Exodus 900 Blue (Czech)
https://linustechtips.com/topic/1491494-pc-weird-lag-need-help/#findComment-15824418
What are the specs of your computer? Are you hitting 100% usage on anything? How are your pc temps?
If all of these are falling under expected and acceptable ranges I would nuke the OS and reinstall it.
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
https://linustechtips.com/topic/1491494-pc-weird-lag-need-help/#findComment-15824430
Specs are
7950X3D
4090 STRIX
64GB DDR5 CORSAIR DOMINATOR RAM
CORSAIR 1600 WATT PSU
ASUS ROG CROSSHAIR X670E EXTREME MOBO
I had windows 11 installed and thought that was the issue, installed windows 10 but still the same deal.
Have just tried putting a 3090 in there to see if that worked, but same result.
Switched ram also same result.
Haven't got a spare CPU but surely that's not the issue.
Temps never really go over 60 for gpu and never really go over 55 for cpu.
Anything else to try? 😞
Nothing is hitting 100% usage either.
Thanks
Mark
https://linustechtips.com/topic/1491494-pc-weird-lag-need-help/#findComment-15824431
4 minutes ago, markplayz said:
Specs are
7950X3D
4090 STRIX
Thanks
Mark
Here are the things I would do in order:
1. Make sure all windows updates are completed.
2. Download Drivers using update utility. GeForce experience for gpu and I believe in your case Armory Crate for mobo.
3. Check for bios updates and install if you have any.
4. Reseat ram and gpu because yolo.
5. Download some program to check drive health.
6. Format drive and reinstall windows.
(Goes without saying but obviously don’t do step 6 if 1-5 fixed your issue haha)
Main Gaming Machine
https://linustechtips.com/topic/1491494-pc-weird-lag-need-help/#findComment-15824434
21 minutes ago, markplayz said:
Specs are
7950X3D
4090 STRIX
Thanks
Mark
Which SSD?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1491494-pc-weird-lag-need-help/#findComment-15824446
6 minutes ago, markplayz said:
WD BLACK 4TB M.2 NVME
What does the WD SSD tool say about it?
Is your motherboard running the latest Bios?
And your chipset drivers, the ones that were released yesterday?
https://linustechtips.com/topic/1491494-pc-weird-lag-need-help/#findComment-15824458
I checked on CrystalDiskInfo said it was 100% good.
I installed latest bios before installing windows
and yes I've updated to latest drivers from yesterday 😄
https://linustechtips.com/topic/1491494-pc-weird-lag-need-help/#findComment-15824460
Not asking about the health, asking about firmware updates.
https://linustechtips.com/topic/1491494-pc-weird-lag-need-help/#findComment-15824466
Sorry I didn't understand, my bad.
I installed the WD Tool and the firmware was in fact out of date, installed the new firmware and restarted the PC, however the issue still remains 😞
I tried loading up CS:GO and when loading into an offline map with bots it would get to just before you load into the map and my entire PC would freeze and need a restart to function again.
I cleared the CMOS battery after this, and that seemed to have fixed my crashing in CS:GO at least for now, but still getting horrible lag when watching videos and loading into any game, and still getting horrible laggy mouse/delayed mouse movements when opening applications or just loading into windows.
Super confused, just built the PC and I don't know what to do 😞
Could there be a BIOS setting I'm missing?
https://linustechtips.com/topic/1491494-pc-weird-lag-need-help/#findComment-15824507
Hm, this is a weird one.
Can you check these questions, maybe we missed something?
https://linustechtips.com/topic/1491494-pc-weird-lag-need-help/#findComment-15824517
I just tested it for a second there, it crashed.
Motherboard was going between 34,35,36 on the debug menu thingy.
I could hear sound but screen completely froze, couldnt alt tab or anything.
Sound eventually stopped and all my monitors went really discoloured, black and stuff then PC rebooted.
https://linustechtips.com/topic/1491494-pc-weird-lag-need-help/#findComment-15824534
I tested another method last night, got a spare GPU that was small enough to fit on the bottom GPU slot as my 4090 is too big to fit in that slot with all the cables below it, everything was fine with that GPU.
I put the GPU back on the top slot and problem reappeared, I'm guessing the GPU slot is broke? hence the crashes etc?
https://linustechtips.com/topic/1491494-pc-weird-lag-need-help/#findComment-15825666
