My first build
1 hour ago, Elliot T. Otterton said:It would be nice to get it cheaper, do you have any recommendations on what ssd / cpu cooler to get? (I'm fine with keeping the current motherboard)
And I definitely am going to do the online windows key.
As far as coolers go, air is the way to go with a chip like the 5600x. It simply doesn't put out enough heat to throttle even on an in-box cooler. The Thermalright peerless assassin 120 se is a steal ($40), and what I plan on upgrading to soon. You could even forgo this entirely, and use the stock cooler. As far as ssds go, there are a load of cheap and pretty decent ssds nowadays. Things like a silicon power a60 are decently speedy and cheap. It's up to you whether the $20 worth of savings are worth the cost of a less reputable vendor (samsung has had its ssd woes recently, though). You could also save a bit of cash on the cpu by going for a 5600 non-x and on the gpu by going with a 6700xt. These combined would result in a performance loss of maybe 5-7% in games, unlike the previous changes (which won't affect performance meaningfully), but you could save $80. Whatever you choose, happy building!
