Budget (including currency): trying to stay within 2500 USD
Country: U.S.
Games, programs or workloads that it will be used for: mainly cod/borderlands/gta/etc and school related or video design
Other details: I have comprised two different lists that are only $100 apart and I would like to know which I should go for. Before you guys say to go for intel, I have my mind set on amd for now and before anyone says to go air cooled, I just don’t want to as an aio looks better and performs better. So with that in mind, what revisions should I make if any and which if the two should I pickFAA9AEA1-5047-4107-A5DE-E4661BD7644F.thumb.jpeg.3e7bae572a512d3681f61d775689a073.jpeg
https://pcpartpicker.com/list/jQHv9r
https://pcpartpicker.com/list/XqHZY9
https://linustechtips.com/topic/1490740-future-build-questions/
And are completely intelligible. Please copy us the PCPP link directly using the field pointed by the orange arrow, or the BBCode markup marked with red arrow and circle.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1490740-future-build-questions/#findComment-15818772
Alright I have added the list links to both under their respective pictures
https://linustechtips.com/topic/1490740-future-build-questions/#findComment-15819112
Yeah you can go with the 7000 series CPU here. But why the 3060? I would downsize the build scheme a lot more if you already have this card, 7950X is overkill for this. But if you dont have the card, here's a quick rebuild for solely gaming. But do be noted that i highly recommend waiting for the X3D variant of the CPU, as theyll be a neck faster.
Also, do you want H5 aesthetic or are you willing to go for other case? Theyre decent but ryzen boost algorithm loves to boost hard so more cooling would pay dividends in CPU bound performance.
https://linustechtips.com/topic/1490740-future-build-questions/#findComment-15819415
