Cpu fans spins briefly then turns off for 2 seconds before spins again continuesly when booting up but no display and no beep sound.
Tried:
-Replace PSU with other sure working PSU.
-Clean ram stick and change slot
-Replace CMOS battery and resetting bios by draining power and shorting the 2 pins.
-used different display cable
motherboard:
Asus ex-h310m
What might be the problem?
https://linustechtips.com/topic/1490283-no-display-please-help/
Reseat the cpu?
Main Rig:
Ryzen 5800x, ASUS Crosshair Hero VII Wi-Fi, 32gb of Corsair Vengence Pro SL 3600 CL18, Sapphire Pulse 9060xt 16gb, Noctua NH-D15 LTT Edition, Soundblaster AE-7, Beyerdynamic DT 990 Edition 600 Ohm headphones, 1tb ADATA SX8200 NVME SSD, 1tb Intel 665P NVME SSD, 500gb Samsung 850 EVO SATA SSD, 8tb WB Black SATA HDD, 14tb WD Ultrastar HC530, LG SATA Blue Ray Drive, EVGA 1300w G+ PSU, Coolermaster Stryker case, ROG ARGB strips, China ARGB fans.
HTPC:
Ryzen 5800xt, ASUS B550M Prime Plus WiFi II, 32GB of Corsair LPX 3200 CL16, ASUS 5060 8gb LP, Noctua L9-x65 cooler, WD Black SN770 500gb NVME SSD, WD Black SN770 1tb NVME SSD, Crucial MX500 2tb SATA SSD, WD Blue 2tb SATA HDD, Pioneer Blu-Ray burner, Intel AX200 WiFi/Bluetooth, Seasonic 300w TFX PSU, Silverstone ML11 case.
Retro Gamer PC:
VIA C3 1000Mhz, VIA Epia PD-10000 LVDS, 1gb of Kingston DDR, PNY Geforce FX5500 128mb PCI, WD 80GB HDD, Random CD-ROM, Random 250w mini psu, Mini ITX case 🤣
https://linustechtips.com/topic/1490283-no-display-please-help/#findComment-15815824
