Never heard of a Ryzen 7 5700X with RGB, are you sure that's the CPU name?
Assuming you're looking for a cooler for the regular 5700X...
... what case are you using?
Because the case dictates the height the cooler can be in order to fit.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1490258-cpu-cooler/#findComment-15815640
Phanteks Eclipse P300 ATX Mid Tower Case
https://linustechtips.com/topic/1490258-cpu-cooler/#findComment-15815642
The cooler should be under 160mm (under 6.3").
What's your budget?
Btw, a 5700X is not hard to cool, so I  guess you're looking at budget options (sub $50) and air (not AIO watercooling).
https://linustechtips.com/topic/1490258-cpu-cooler/#findComment-15815651
9 minutes ago, Gokul_P said:
Thermalright peerless assassin should work if it is not a small form factor build.
It would work, but it might be over-budget and it's not RGB (so the fans should be swapped to some RGB ones which is additional cost).
https://linustechtips.com/topic/1490258-cpu-cooler/#findComment-15815658
Nah The ARGB ones pretty cheap (that is The cheapest) https://pcpartpicker.com/product/zyNxFT/thermalright-peerless-assassin-120-se-argb-6617-cfm-cpu-cooler-pa-120-se-argb
https://linustechtips.com/topic/1490258-cpu-cooler/#findComment-15815675
17 minutes ago, Gokul_P said:
That's a great option.
https://linustechtips.com/topic/1490258-cpu-cooler/#findComment-15815685
