Hi!, so I just build my PC and the fans, ram, gpu and mobo light up and works fine but no display so I immediately knew I had to flash my bios and I did that but now its the same thing and also the USB seems to work when I plug my phone into it it charges it but when i plug my rgb mouse and keyboard they don't light up
Specs: https://pcpartpicker.com/list/sjfjVw
https://linustechtips.com/topic/1489177-pc-built-but-not-posting/
Check all cables and connections. Sounds like you may have a front panel header connector off one pin or something.
I have to ask, why a 5600G with a dedicated GPU? Ryzen G's give up performance over a non-G or an X.
Which brings to mind, which display output are you plugged into, the card or the board? If it's defaulting to the G's iGPU, that would explain this if it's displaying through the board and not the dedicated GPU.
Edited by An0maly_76
Revised, more info
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
Just now, Jadtrugaming said:
I checked but I dont think that would stop it from displaying stuff
I've added to my post, re-read it.
Asus' compatibility list for this board / CPU does not include your RAM SKU of CMW16GX4M2D3600C18W. Ryzens and supporting boards are quite funny about RAM, I've seen no-video POSTs like this before with my 5900X because it didn't like the RAM I used. Freezing in sleep mode, no-video POSTs, a few random crashes here and there.
so what do I do then?
Absence from the compatibility list doesn't guarantee it wont work, but it doesn't guarantee that it will either. You may have to get a RAM kit listed as compatible. So much the better if you can borrow a kit that is listed as compatible, to see if the problem goes away.
I checked and doesent look like you have a Dr Debug.
It looks like you have 2 sticks of ram. when look straight at your motherboard, if the RAM slots (left to right) are 1,2,3,4 - which slots did you put the RAM in? Normally you’re supposed to use slots 2 &4.
Did you check the ram to make sure it’s all the way seated? Either way, remove both RAM sticks and put only 1 stick in to see if you can get it to post. Make sure you hear a distinct “click” (very important).
It doesent look like you have a clear cmos button. What did you do to clear the cmos?
yep all checked
6 minutes ago, Jadtrugaming said:
yep all checked
And you tried just 1 stick of ram, correct?
Next step would be to unplug pretty much everything from your motherboard including the fans (probably leave the CPU cooler) to see if you can get it to post without anything connected.
After that, you’ll need to check to make sure you didn’t bend any pins on the processor. Your AMD processor has extremely fragile pins and bending or breaking  even one would cause major issues.
I unplugged everything thing reseted the cmos, tried 1 stick of ram now Im down to just checking if my cpu is fine
just checked and my cpu pins are fine
