After a few days my gpu will stop running at full power it will be at 30-55w and will get 30fps instead of normal 50- 60fps in games
The only solution is to unplug from motherboard and reset then it seems to work for a few days
And ideas ?
1650 72w
msi mortar b365m
New 550w psu
https://linustechtips.com/topic/1487967-gpu-power-problems/
And ideas ?
1650 72w
msi mortar b365m
New 550w psu
Did you just upgrade to that card? If so, what was the previous card used?
https://linustechtips.com/topic/1487967-gpu-power-problems/#findComment-15798611
4 minutes ago, kenpachi213 said:
Had it for 3 years since new
Upgraded from a 750ti
interesting. Nvidia control panel messes up the clock speeds sometimes and it can get stuck in idle. Open nvidia control panel>Manage 3D settings>Set power management mode to high performance and reboot. If this does not work you could try to use DDU and reinstall the Nvidia drivers. That is one of the first things to do when a GPU is acting funny.
https://linustechtips.com/topic/1487967-gpu-power-problems/#findComment-15798615
8 minutes ago, kenpachi213 said:
msi mortar b365m
See if there is anything wrong with the PCIe settings in the BIOS. Since you mentioned that your graphics card is a sub-75W model, it's probably getting all the power from the motherboard. Something could be affecting the power delivery settings.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1487967-gpu-power-problems/#findComment-15798620
Well I just took it out of mobo and cleaned gpu connector and of course it's running 100% again lol I was in bios but don't really know what to look for lol
https://linustechtips.com/topic/1487967-gpu-power-problems/#findComment-15798625
Don't all of that many times lol
https://linustechtips.com/topic/1487967-gpu-power-problems/#findComment-15798627
And ideas ?
1650 72w
msi mortar b365m
New 550w psu
What game are you trying, And maybe there is bios settings issue or driver issue.
https://linustechtips.com/topic/1487967-gpu-power-problems/#findComment-15798631
7 minutes ago, kenpachi213 said:
Well I cleaned gpu connector it had black dirt on most of the pins or wteva so I cleaned and now it's ok
Look the mb part too that is prob the only issue that you had evey time you replugged the connection becomes ok and after some time due to the build up it loose the connection
https://linustechtips.com/topic/1487967-gpu-power-problems/#findComment-15798659
In the BIOS, the PCIe x16 slot would probably have its own settings menu. If the only thing you can do is change between PCIe 3.0 and 2.0 you probably don't have a issue there.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1487967-gpu-power-problems/#findComment-15798828
