21 minutes ago, VSIP said:
Hey,
I have a H410M-B with a cpu fan any one system fan plugged in, and i want to plug 2 more fans in but i cant find any more pins for the fans, does my motherboard really only have 2?
Is your motherboard the PRO version?
Edit - I see a cpu fan header and a system fan header for the PRO version on msi website I am guessing that is your motherboard. You can use a fan hub connector to connect multiple fans.
https://linustechtips.com/topic/1487312-system-fans/#findComment-15793917
25 minutes ago, aDoomGuy said:
You can use fan splitters.
Or a fan hub (nicer solution imo, cost $10)
https://linustechtips.com/topic/1487312-system-fans/#findComment-15793962
