System Information:
Operating sys: win 11
Processor: AMD Ryzen 5 5600x 6- core and 5600
Graphics: RTX 3070 8 gb
Motherboard: TUF GAMING gaming A520M-
Ram: 16 gb ram 3200 mhz
1 TB ssd
700W PSU
Problem:
I have recently replaced my 5600x with a brand new 5600 to check if the x was defective, following that I had no issues for a week, I then tried to put back in the 5600x and the PC refused to POST with the 5600x or the new 5600, the fans and RGB lights including motherboards will turn on, I can use the MB button too. I tried reseating the cpu, ram and gpu multiple times. My BIOS is updated and both cpus worked before. I believe it’s a motherboard issue but I want to hear from the community first. I will list the methods of troubleshooting I have tried so far:
1. Reseated CPU and paste
2. Reseated RAM and used new pair
3. Reseated GPU and used new one
4. Used NEW PSU
5. Cleared CMOS by battery and pins
6. Reseated cooler
7. Tried a speaker cable but no beeps on power
https://linustechtips.com/topic/1484906-no-post-after-replacing-cpu/
sounds like motherboard issue, but can you first check the pins on the cpu, and if some are bent or broken off, check the motherboards cpu slot for any stuck pins that may be interfering
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3DSapphire Nitro+ 7900XTX 24GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / EVGA SuperNova 850 G2 / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / iiYama 1440p 165HZ Montitor, iiYama 1080p 75Hz Monitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 3Ghz Core 2750Mhz Memory w/ 25%W increase (460W)
I dont believe any of the cpu's have bent pins, motherboard cpu spot looks fine to me, is there any way to test motherboard?
you could seat the cpu in another motherboard
Setup:
