Budget (including currency): £1200 (GBP)
Country: United kingdom
Games, programs or workloads that it will be used for:  Minecraft with rtx (+java shaders), light video editing, indie games
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Planning to buy a 1080p
144-165hz monitor. Would be happy to stretch to £1250 if necessary. Already have a keyboard and mouse. P.S not planning to overclocking and will upgrade to dual-channel 32GB later down the line. PCPartPicker link: https://uk.pcpartpicker.com/list/xYNJ9r
https://linustechtips.com/topic/1484789-first-pc-build/
