Performance power management features on processor. Kernel processor problem. I need help
Hello, i need some help.
My pc with specs:
ryzen 5 3600
rtx 3060
b450-f gaming
16gb ddr4 rgb pro corsair ram
750W 80+ white PSU
recently started getting the error on all processors: Performance power management features on processor 2 in group 0 are disabled due to a firmware problem. Check with the computer manufacturer for updated firmware.
I know its kernel processor power problem but i dont know how to fix it. It just started appearing out of nowhere and my pc is almost unusable because when i try to play a game it just crashes.
Pls Help
My pc with specs:
ryzen 5 3600
rtx 3060
b450-f gaming
750W 80+ white PSU
Pls Help
Start by launching the Command-Prompt as admin. powercfg -duplicatescheme e9a42b02-d5df-448d-aa00-03f14749eb61 and press enter. You should now have the Ultimate Performance plan listed under the Power Options. then see if it lets you select it
if not try doing this command under admin command prompt sfc /scannow
did you update BIOS and chipset drivers?
Desktop benching:
