First Build
Go to solution Solved by TylerD321,
1 hour ago, xdbutter said:
Sorry i didnt get what you meant over here. "AIO would good"
Here is what the 7000d supports in terms of aio and fans. You could even go crazy with cooling and get a 420 or 480mm aio. If you wanted.
Budget (including currency): 2700 USD
Country:
Games, programs or workloads that it will be used for: Revit, CAD software, Simulations, RDR, GTA, NFS
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Have been using laptop. Will be my first PC.
PCPartPicker Part List: https://pcpartpicker.com/list/VMN2C6
CPU: AMD Ryzen 9 7950X 4.5 GHz 16-Core Processor  ($589.99 @ Amazon)
CPU Cooler: Asus ROG STRIX LC II 80.95 CFM Liquid CPU Cooler  ($229.99 @ B&H)
Motherboard: MSI MEG X670E ACE EATX AM5 Motherboard  ($699.99 @ Newegg)
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400 CL32 Memory  ($194.99 @ Newegg)
Storage: Samsung 980 Pro 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($119.99 @ Amazon)
Video Card: Asus ROG STRIX GAMING OC GeForce RTX 4070 Ti 12 GB Video Card  ($1049.99 @ ASUS)
Power Supply: Asus ROG THOR 850P 850 W 80+ Platinum Certified Fully Modular ATX Power Supply  ($179.99 @ Amazon)
Total: $3184.92
Generated by PCPartPicker 2023-01-23 16:25 EST-0500
Case:?????
  • I want to have something robust. Also having the option to upgrade in future.
  • No RGB Needed. Just performance.
  • Some of the components are just there to show what storage or memory capcacity I want.
https://linustechtips.com/topic/1483476-first-build/
Country:
Total: $3184.92
Case:?????
You might want to get a slightly better CPU cooler, but other than that this build is fine.
Have you tried turning it off and on again? Maybe Restart it?
Please make sure to Mark the Solution as a Solution.
Take everything I say with a grain of salt. I could be just about wrong as I am right.
Main RIG
13600K (Undervolted) +MSI Z690 Edge Wi-Fi+ Team Elite 32gb RAM (3200) +Noctua Nhd-15 Chromax Black+ Intel 670p 1TB SSD+ EVGA FTW Nvidia RTX 3090+ Corsair Crystal 465x case+ EVGA SuperNOVA 650W PSU.+ ASUS VP222 Gaming Monitor
Laptop for School: Surface go 2 (sucks ass)
Laptop for tinkering: Dell Inspirion 3358
Audio: Apple Airpods Pro (1st Gen)
(Apple_reigns_ supreme_ forever_ and_ ever)
(I am 16 years old and don't know shit about fucking shit.)
Everyone must suffer one of two Pains: The pain of Discipline or the pain of regret and disappointment.
-Jim Rohn
https://linustechtips.com/topic/1483476-first-build/#findComment-15765474
Take a look at this post to get a feel for how coolers compare if you decide to change:
As far as the case goes, you can't go wrong with a Corsair 4000D/5000D airflow case for mid sized. If you are into full sized you could consider maybe the 7000D airflow?
Edit: Here are some posts rating power supplies and storage if you want to look into that as well.
Edited by TylerD321
Added links
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
https://linustechtips.com/topic/1483476-first-build/#findComment-15765483
Thank you very much for your help.
Have changed the cooler and added the case.
PCPartPicker Part List: https://pcpartpicker.com/list/cYnjxs
CPU Cooler: NZXT Kraken Z73 73.11 CFM Liquid CPU Cooler  ($284.99 @ Amazon)
Case: Corsair 7000D AIRFLOW ATX Full Tower Case  ($229.98 @ Newegg)
Total: $3469.90
Generated by PCPartPicker 2023-01-23 17:00 EST-0500
Can you also please suggest some cooling fans. I have tried looking but cant figure out which ones would be best.
https://linustechtips.com/topic/1483476-first-build/#findComment-15765519
Got it. Thanks
Update.  Do you think this one is okay?
Total: $3469.90
https://linustechtips.com/topic/1483476-first-build/#findComment-15765522
1 minute ago, xdbutter said:
Got it. Thanks
Total: $3469.90
Better. But be careful because AIO's have to be replaced a lot more frequently than Air coolers.
Main RIG
-Jim Rohn
https://linustechtips.com/topic/1483476-first-build/#findComment-15765526
Just now, xdbutter said:
ah i see. Thanks again.
Can you suggest one that you think would be best for this this build.
 AIO would good. I wouldn't get a Air cooler because you went Ryzen instead of Intel and Ryzen is significantly cooler. and has a lower TDP.
Main RIG
-Jim Rohn
https://linustechtips.com/topic/1483476-first-build/#findComment-15765535
Main Gaming Machine
https://linustechtips.com/topic/1483476-first-build/#findComment-15765577
my fault AIO would be good
Main RIG
-Jim Rohn
https://linustechtips.com/topic/1483476-first-build/#findComment-15765601
23 minutes ago, TylerD321 said:
Here is what the 7000d supports in terms of aio and fans. You could even go crazy with cooking and get a 420 or 480mm aio. If you wanted.
Cooking? lol
Main RIG
-Jim Rohn
https://linustechtips.com/topic/1483476-first-build/#findComment-15765603
21 minutes ago, FI Fheonix said:
Cooking? lol
Autocorrect but I’ll call it a happy accident since you could consider running some cpus cooking.
Main Gaming Machine
https://linustechtips.com/topic/1483476-first-build/#findComment-15765624
