Hey guys, quick question :
When you shut down your pc and cut off power, the OS starts and thinks its the time you plugged out your power cable; after you've plugged it in again.
My Question is: If the CMOS Battery powers "Memory" to save the bios settings then why doesn't it just keep the clock going ?
Because my laptop doesn't stop its clock, when every power source but the CMOS battery is removed. (Yep I thought of the battery ^^)
Does anybody have an answer ?
THANKS !
https://linustechtips.com/topic/148304-cmos-battery-clock-win-7/
I would imagine the reason why not would be to not drain the battery or put any extra strain at all on it. I do not actually know the answer but that  is my best guess.
"If you do not take your failures seriously you will continue to fail"
https://linustechtips.com/topic/148304-cmos-battery-clock-win-7/#findComment-1980588
