AMD fTPM Help
Go to solution Solved by 191x7,
Bios version?
I just recently setup my new PC but I am having trouble with the TPM as it's not being detected by Windows. However, AMD PSP 11.0 is showing on Device Manager but no TPM is showing via tpm.msc. Please help me fix this issue.
This is what I have enabled in BIOS:
Security Device Support = [Enable]
AMD fTPM Switch = [AMD CPU fTPM]
BIOS UEFI/CSM Mode = [UEFI]
Secure Boot = [Enable]
Specs:
CPU: AMD Ryzen 5800X3D
MB: MSI MAG X570S Tomahawk MAX WIFI
Memory: Corsair Vengeance Pro 32gb 3600Mhz
Storage: Samsung 980 Pro 1TB SSD
GPU: AMD 6950XT
https://linustechtips.com/topic/1482386-amd-ftpm-help/
Bios version?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1482386-amd-ftpm-help/#findComment-15757911
1 minute ago, B1Lancer656 said:
Just checked the date and apparently it was updated before support for the 5800X3D came out. I'm currently going to flash the BIOS to see if that issue is fixed.
Ok, let us know.
https://linustechtips.com/topic/1482386-amd-ftpm-help/#findComment-15757918
5 minutes ago, B1Lancer656 said:
It worked. Thank you!
Don't forget to use the latest chipset drivers.
https://www.amd.com/en/support/chipsets/amd-socket-am4/x570
Glad it worked for you. Agesa 1.2.0.7 is good. 1.2.0.8 comes out soon.
https://linustechtips.com/topic/1482386-amd-ftpm-help/#findComment-15757952
