Kolink Void X GPU Cooling
Solved by OddOod,
Nope. There is no new air supply to that region. At best you'd just be stirring the air around a bit which won't be a noticeable improvement.
You'd have to cut out the PSU shroud, then cut holes in the bottom at which point you're putting in a LOT of effort to compromise the structural integrity of the case instead of getting a better case.
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
4
derekchan ·
Posted in New Builds and Planning8 -
1
2
6
5
7
kerriya ·
Posted in Cases and Mods14
play_circle_filled
Latest From ShortCircuit:
