my fiancee wanted to build a new pc and has mostly everything the same as mine so i'm not sure why his stuff is having issues..
The zotac rtx 4080 worked fine on initial boot , but once we updated/installed the nvidia drivers we get a simi frozen flickering display . we thought it might have been the gpu but i tried my spare working 3080ti in it and had the same issue. we thought it might have been the motherboard but we ordered a different one and it has the same issue. i tried disabling the mobo graphics and it freezes when it tries to boot into windows. i can get into the bios ok before that happens. we tried sticking his ssd from his other pc that has windows 10 on it ( we had got him 11) and it worked fine until i updated the drivers then the same issue happened thankfully i put the other drive back in its original pc n theres no issue with that . i have no idea what the case is at this point or what to do honestly.
PSU: Corsair HX1000i, HXi Series, 80 PLUS Platinum Fully ModularMOBO: GIGABYTE Z690 AORUS ULTRA LGA 1700 Intel Z690 ATX Motherboard with DDR5 ( same as mine , BIOS updated to F22)
CPU: Intel Core i7-13700K
GPU: ZOTAC Gaming GeForce RTX 4080 16GB Trinity OC 16GB GDDR6X 256-bit 22.4 Gbps PCIE 4.0
Fasgear PCIe 5.0 GPU Power Cable Sleeved 70cm | 16pin(12+4) 12VHPWR Connector for RTX 3090 Ti/4080/4090 ( i use the same one for mine)
RAM: Corsair Vengeance RGB DDR5 64GB (2x32GB) 5200MHz C40 AMD Optimized Desktop Memory
Cooler: CORSAIR iCUE H150i ELITE LCD Display Liquid
Storage: WD_BLACK 2TB SN850X NVMe Internal Gaming SSD Solid State Drive - Gen4 PCIe, M.2 2280, Up to 7,300 MB/s - WDS200T2X0E .... windows 11 installed
as i was typing this i thought maybe it was a ram issue since his has amd optimized in the title so i tried pulling my ram from my pc but it didn't help at all Corsair Vengeance DDR5 64GB (2x32GB) 5200MHz C40 Intel Optimized Desktop )
i've attached a video of what it originally did the first time we tried it, since then it either just comes up with a thick line at the top with a black screen with a lighter black/grey line at the top  or a black and white combo of weirdness flashing
