Rgb strip light help
5800X3D | RTX 4070 | 32GB RAM | 1TB NVME (boot) | 2TB NVME (storage) | B550M DS3H | Samsung S90F 65" OLED | Denon x1700h 5.1 Surround Sound
https://linustechtips.com/topic/1479127-rgb-strip-light-help/#findComment-15736025
9 minutes ago, Holmes108 said:
Awesome, thanks. These are the ones I got. When I get home I’ll check what ones I need.
Limited-time deal: 100ft Led Lights Strip for Bedroom, L8star 30m Ultra Long RGB Led Lights with 44 Keys Remote and App Control Smart Music Sync Led Light Strips DIY Mode for Christmas Home Decoration https://a.co/d/3RtNC9J
Yep, depending on the connection you probably need something like this (not sure why the links are so long and unruly).
Edit: There are different types and styles so you may want to search around a bit.
https://www.amazon.ca/RGBZONE-16-4ft-Extension-Connect-Connector/dp/B08TWSM4FQ/ref=sr_1_4_sspa?crid=1B4N2KQEDIDZ8&keywords=rbd+led+strip+extension&qid=1672937172&sprefix=rbd+led+strip+extension%2Caps%2C112&sr=8-4-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExU0RPSEVFVVRYMENYJmVuY3J5cHRlZElkPUEwMzUyNTcxMURaVUtUWlVFQktRVCZlbmNyeXB0ZWRBZElkPUEwMDE4Njc3N1czS0dUR09HVTRVJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
Another one:
https://www.amazon.ca/dp/B0B1ZDJG7P/ref=sspa_dk_detail_0?pd_rd_i=B0B1ZDJG7P&pd_rd_w=RGRzn&content-id=amzn1.sym.c7dca932-da6a-44fc-af09-cc68d2449b34&pf_rd_p=c7dca932-da6a-44fc-af09-cc68d2449b34&pf_rd_r=YXQZANGE3TZH6F9X7SKT&pd_rd_wg=ZQblm&pd_rd_r=a061ceda-1eb8-409a-aba9-4e643f18c2e1&s=hi&sp_csd=d2lkZ2V0TmFtZT1zcF9kZXRhaWw&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExWTgxV0NJSldHRjdKJmVuY3J5cHRlZElkPUEwNzk5NTU0MVRZM0c0QTdNMjY2NiZlbmNyeXB0ZWRBZElkPUEwMzA0MTM4MjRYM1RYNDIxM0o1MyZ3aWRnZXROYW1lPXNwX2RldGFpbCZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU&th=1
https://linustechtips.com/topic/1479127-rgb-strip-light-help/#findComment-15736038
Nice. Maybe someone else can chime in and confirm what will work 100%. It appears your set has a regular male/female 4 pin connectors in the pic, but I don't see it specifically stating the connection.
I've ordered several LED strips over the years, but I always try and order kits that are as "all in one" as possible, because like you, I'm not really an expert with the different connectors, voltages, etc etc. But like I said, based on the pics of your set, and the extension in my first link especially, I'm pretty sure you'd be good to go.
https://linustechtips.com/topic/1479127-rgb-strip-light-help/#findComment-15736133
