I would greatly appreciate some recommendations for a surveillance camera to put in my backyard, which ticks the following requirements:
  • has its own battery, with good autonomy (~8 hours), no external power source required
  • has good night vision capabilities
  • can record on SD card (or internal storage alternatively) at 720p and higher, at 30fps at least
It's important that the camera is highly autonomous and can also withstand outside weather. Discreet dimensions and appearance would be a plus. WiFi / Bluetooth connectivity is not essential.
https://linustechtips.com/topic/1478471-surveillance-camera-recommendation/
Is this going to be permanent? If so, there are a TON of cameras with the ability to add a solar panel to power them.
Is this going to be moved frequently? Look into a trail cam for hunting. (i get you want videos, but without knowing your use case for this it's possible a trail cam would suffice for keeping track of potential intruders or 'visitors')
