Hi, I have a i9 9900k and a 3070 with 32 GB of ram but when I play CSGO my fps drops to 80 sometimes and in valorant it also does the same thing. Does anyone know why this might be happening I feel like I should definitely be getting higher constant FPS. I'm not really tech savvy but I can record a video if needed of me playing csgo and having constant fps drops to 80 or valorant. This has been a problem since I bought the computer but just figured the drops were part of the games.
https://linustechtips.com/topic/1477762-computer-fps-problem/
check your cpu and gpu temps, but also uninstall graphics drivers with DDU and download and install latest drivers for your card, make sure your ram is running at its correct speed in bios..XMP profile
DDU display driver uninstaller
CORETEMP for cpu temps and CPUZ to then give it a quick stress whilst coretemp is open so you can see the temp
FURMARK that will show the graphcis cards idle temp then give it a quick stress in the app to see what the temp goes to
If you are not savvy with any of the above I suggest googling guides on them
https://linustechtips.com/topic/1477762-computer-fps-problem/#findComment-15727243
Run the games from an SSD. Those drops are loads from the HDD.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1477762-computer-fps-problem/#findComment-15727272
