Weird usb drive
Solved by Needfuldoer,
It's probably in a Linux format that Windows doesn't understand.
You can use a tool like GParted to completely erase the flash drive and create a new exfat, NTFS, or FAT32 file system on it.
This tutorial was written for Ubuntu, but it's the same application:
https://www.howtogeek.com/howto/17001/how-to-format-a-usb-drive-in-ubuntu-using-gparted/
Here's how to do the same thing with the Windows command line tool DiskPart:
https://www.pendrivelinux.com/restoring-your-usb-key-partition/
