Hi, so for about a week or two now I have been having problems with crashing while playing games. What happens is both of my monitors will freeze and a diagonal pattern of white boxes will show up over the screens. Then either my PC will restart, or the game will close and I'll be back at my desktop. This happens about once every day or every other day. I have already tried using DDU to reinstall my video drivers, done a memory check, done a disk check, and scanned for corrupt files. Nothing I have done has fixed the issue. I have checked the event logger and seen LiveKernelevents 117, 141, and on one occasion 164. What is going on, is my GPU dying? I will also include my specs below. Help would be greatly appreciated.
PC specs
AMD Ryzen 7 3700X
ASUS ROG Strix X470-F Gaming
16gb(2x8gb) DDR4 3600 CL 16
Nvidia GeForce RTX 2080 TI Founders Edition
240gb SATA SSD
1TB hard drive
EVGA SuperNova 750W 80+ gold fully modular power supply
Edit: forgot to mention I checked temps for my GPU and CPU during a long gaming season. highest GPU ever got was 77 C and highest CPU got was a single spike to 81, but averaged around 70-75 C
https://linustechtips.com/topic/1477062-checkerboard-screen-crashing-problems/
You mean like this?
IMG_20210223_134532.thumb.jpg.be0fa0f93c
If so that is the textbook definition of VRAM overheating or dying. What you can do is, download MSI afterburner and set your fan speed to maximum and see if it happens again. If it doesn't happen or happens later than usual, you may get away with servicing the card, else you might have start looking at your options.
3 minutes ago, Levent said:
You mean like this?
  Reveal hidden contents
Not exactly, the squares are much bigger, they don't look like static like in the picture  very similar to this picture
Yeh, that's almost certainly a VRAM issue.
As Levent suggested, download MSI Afterburner and try setting your fans at 100% to see if its a temperature issue.
If that doesn't work, try downclocking your VRAM speed. Knock 25% off to start with and try playing a game. With your VRAM running slower, you will most likely see a performance drop but if it solves the problem you'll know what the culprit is. Slowly increase the speed until the problem returns but from here your either going to have to live with a GPU that you're intentionally running slower that it should or needing to buy a new one.
*IMPORTANT* - Mem clock NOT GPU / Core clock.
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
Aight, I was planning on cleaning my PC out tomorrow anyway, so I'll do that and mess with fan speeds and see if that fixes it, thanks for the help
14 hours ago, Cyberat said:
CPU temps more alarming than GPU, although the artifacts are GPU based, does not mean they originate plainly from GPU texturing.
Set fans for 100% at 60C for CPU in Bios, for GPU in Drivers or Afterburner, whatever Team Green uses.
I cleaned the PC out and increased my fan curve, yet the problem persists, do I need to RMA my card? Could it be something other than my GPU?
