Hello, I'm running a 6 core 10th gen i7. Currently have the stock intel cooler. Im finding really high temperatures since I have quite a warm build. Getting some more case fans, but also want to upgrade my CPU's cooler. However, my problem is that I have a Micro ATX motherboard, and basically no clearance for a bigger cooler. Does anybody know of a cheap(ish) cooler I can get that is around the same size as this stock intel one?
https://linustechtips.com/topic/1476841-cpu-cooler-upgrade/
What exactly do you mean by clearance? What would get in the way?
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1476841-cpu-cooler-upgrade/#findComment-15720856
3 minutes ago, 50MinZ said:
RAM
RAM would be an issue oonly with super massive coolers DH15 style, get anything medium size (Esports 34, AK400, ...) and you'll be good
Thought i7 never shipped with crap stock coolers
https://linustechtips.com/topic/1476841-cpu-cooler-upgrade/#findComment-15720877
I really dont think so.  Current cooler is millimetres away from touching the chunky corsair vengeance pro RAM I got. I cant find a single cooler that will provide more airflow and be the same size/smaller. And believe me, I have searched for hours.
https://linustechtips.com/topic/1476841-cpu-cooler-upgrade/#findComment-15720880
6 minutes ago, 50MinZ said:
I can try to get a photo if you'd like.
Yup
Do you have a special super cramped mobo ?
Because with mostly any standard one there's no issue at all, look this for example, and you can even put the fan on the rear...
https://linustechtips.com/topic/1476841-cpu-cooler-upgrade/#findComment-15720895
That looks like you have enough room for a number of inexpensive tower-style air coolers. The RAM is tall, but plenty of air coolers stay far enough back that it won't be an issue. For example, the Thermalright Assassin X 120 is on sale right now for just $20, or there's an RGB version for $23 if you want to go that route: https://smile.amazon.com/dp/B09LHBFPJ6
https://linustechtips.com/topic/1476841-cpu-cooler-upgrade/#findComment-15721144
Yeah, I was thinking something a bit more powerful as I have around $120 to spend and would just rather get one that works great and I wont have to replace though.
https://linustechtips.com/topic/1476841-cpu-cooler-upgrade/#findComment-15721162
I don't typically think of $120 as "cheap(ish)" but if you're looking to go all-out, then the best compact air cooler is probably the Scythe Fuma 2. It looks bigger than it is, but the RAM won't be an issue because the heat pipes bend away and it has a thin front fan. Sadly, it's out of stock or being scalped by marketplace sellers on Amazon and Newegg. If you live near a Microcenter, they'd probably have it in stock. EDIT: Just looked and it's basically sold out at all Microcenter stores, too.
Otherwise, you could go with an all-in-one liquid cooler (AIO) with that budget pretty easily. If your case can handle a 240mm or 280mm, there are plenty around the $100 price point. Probably the best option there would be the Arctic Liquid Freezer II 240 that Amazon has for $98: https://smile.amazon.com/dp/B07WSDLRVP
What case do you have?
https://linustechtips.com/topic/1476841-cpu-cooler-upgrade/#findComment-15721169
I have the GameMax Kamikaze Pro. I think its a decent size but im not sure.
https://linustechtips.com/topic/1476841-cpu-cooler-upgrade/#findComment-15721172
That case does support 240mm AIOs in both the top and front, so you can definitely go that route. The pump block definitely won't interfere with your RAM. I'd recommend mounting the radiator in the top if you decide to get an AIO, as that'll give you the best long-term experience.
https://linustechtips.com/topic/1476841-cpu-cooler-upgrade/#findComment-15721180
I'd have to sacrifice 2 case fans for that though.
https://linustechtips.com/topic/1476841-cpu-cooler-upgrade/#findComment-15721214
I don't see case fans in the picture you posted - I'm talking about the top of the case above the motherboard, not the top 2 fans in the front of the case.
Even if you do have 2 case fans mounted in the top of your case, you won't really lose that much exhaust, because you will get airflow from the AIO's radiator. It won't be as much because it has to push air through the radiator fins, but it's not a complete loss.
https://linustechtips.com/topic/1476841-cpu-cooler-upgrade/#findComment-15721223
Yeah, I got some extra fans installed up there.
https://linustechtips.com/topic/1476841-cpu-cooler-upgrade/#findComment-15721226
