I need help
Go to solution Solved by kb5zue,
35 minutes ago, Gokul_P said:
Can you use English. هل يمكنك استخدام اللغة الإنجليزية
Unfortunately, can't offer any help if we can't read it.  Sorry.
تم إيقاف تشغيل الكمبيوتر من تلقاء نفسه دون أي إشارة أو سبب منطقي. حاولت تفريغ المكثفات وغيرت مكان الذاكرة. قمت أيضًا بإزالة بطارية الساعة وقمت بتثبيتها مرة أخرى ، لكن المعالج لم يعمل. ما هو الحل لأنه لا يوجد رد فعل في الكمبيوتر سوى الإضاءة؟
اللوحة الأم b450 النخبة
Edited by Anas_Alaakil
https://linustechtips.com/topic/1476434-i-need-help/
https://linustechtips.com/topic/1476434-i-need-help/#findComment-15718477
4 hours ago, kb5zue said:
لسوء الحظ ، لا يمكن تقديم أي مساعدة إذا لم نتمكن من قراءتها. آس
The computer turned off while it was working and was stable on its own without any sign or logical reason, and I disconnected it from electricity to discharge the charge of the capacitors, and after that I removed the clock battery located above the motherboard and changed the location of the memory, but to no avail, as the processor is still turned off and flash is given White on the b450 elite motherboard
https://linustechtips.com/topic/1476434-i-need-help/#findComment-15718745
https://linustechtips.com/topic/1476434-i-need-help/#findComment-15718746
What light is Flashing (Which color). and what is say near it
https://linustechtips.com/topic/1476434-i-need-help/#findComment-15718747
23 minutes ago, Anas_Alaakil said:
White color blinking on auros logo and when i press the power button there is no thing happened
What is This Marked Led Is doing (off/stable/blinking if it is blinking how much time is it blinking without a pause with a small pause) is your Mb B450 AORUS ELITE. If it is not can you confirm which Board do you have
https://linustechtips.com/topic/1476434-i-need-help/#findComment-15718773
