PC temps...
Go to solution Solved by vertigo220,
Perfectly normal. Those are very good temps for max.
SO, I'll just say right now that I am the type of person who worries over nothing haha
Just replaced my 3060ti with a Gigabyte Aorus master 3070ti. My cpu is a 5800x cooled by an arctic liquid freezer 2 240.
Under full load the gpu hits 75-80 (77 highest I have personally seen it so far) and cpu 60 ish under full load. The tempered glass case panel gets warm to touch and given that the pc is right next to me of course I feel the heat. My radiator is top mounted with fans as intake, rear fan exhaust and 2 front mounted Noct case fans as intake. It's in a Carbide 275R (none airflow.)
Just wanna make sure this is all normal. Like I said, I'm known for worrying over nothing.
BTW the radiator behind the pc is turned off so it never comes on.
Thnaks!
https://linustechtips.com/topic/1476118-pc-temps/
7 minutes ago, Christrix said:
Thanks! I actually edited my case fan speeds and managed to shave another 5-10 c off too!
I mean, you can do that, but there's no reason to. The components are fine at the temps they were at, and even higher, so all you accomplish by bumping the fans up is making things louder. The same heat is generated either way, it's just that it's getting moved out of the case and into the room a bit faster. It's not magically making the PC generate less heat, and it's not going to make it run faster or last longer, at least not appreciably.
https://linustechtips.com/topic/1476118-pc-temps/#findComment-15716460
