Hello!
Currently I have a Buffalo 4TB NAS (2 TB Useable because of RAID), currently it is full of mostly pictures my family takes lots of high res raw files. So storage can fill up pretty fast, therefore I am looking to upgrade it. We don't really use plex or anything similar, however this could change. While I dont know of any solution in particular I would love to self host a photo sharing site for the family photos that isnt google drive or similar. Because I am a cheapskate I am thinking of buying an old used dell optiplex or similar and taking the hardware out of the case and putting it in some other case. Which leads me to my first question, what are some good options for cases here? I dont care if they are rack mount or not. In total I would like about 10TB with one drive for parody, with some room to expand it down the road when the need arises. Second question is, if I keep the optiplex in its case are there any diskshelfs, JBOD type encloseures, etc that will suit my needs or does it not make sense to go this route. Thanks for the help in advance.
https://linustechtips.com/topic/1475676-nas-build-questions/
8 minutes ago, EastCoastSunrise said:
parody
parity*
2x 10TB drives, and any computer will work.
though parity isn't a backup, it helps for downtime, but hopefully you don't have a drive fail while rebuilding the array.
as far as software I have been using photoprism and I like it a lot, has a lot of features similar to google photos, though I use it as a single user, so I don't know how well it will work for multiple people.
You can also setup a nextcloud instance
If your question is answered, mark it so.  | It's probably just coil whine, and it is probably just fine |   LTT Movie Club!
Read the docs. If they don't exist, write them. | Professional Thread Derailer
Desktop: i7-8700K, RTX 2080, 16G 3200Mhz, EndeavourOS(host), win10 (VFIO), Fedora(VFIO)
Server: ryzen 9 5900x, GTX 970, 64G 3200Mhz, Unraid.
https://linustechtips.com/topic/1475676-nas-build-questions/#findComment-15713138
12 minutes ago, EastCoastSunrise said:
Hello!
if you are going old optiplex mother board route make sure that thing uses a standers screaw layout. Dell is the one that uses every thing on their system proprietary.  Iam using a ExtremeMachines NAS HDD Storage Server Case (its an chinese oem case with brand name slapped on the perticular one that i got have no markings about the company) with a  mini itx board and 4 2 tb harddrives totalling 4tb usable storage after raid. Case is very cheaply build but it does the job for me.
https://linustechtips.com/topic/1475676-nas-build-questions/#findComment-15713140
Have you checked with Buffalo or documentation if you can just replace the drives in your RAID?
Most NAS devices and Array softwares you can just replace the drives one at a time (waiting for the new drive to rebuild before replacing the next) with larger drives, to expand the storage capacity.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/1475676-nas-build-questions/#findComment-15713595
