Budget (including currency): 2000-2500 USD
Country: United States
Games, programs or workloads that it will be used for: MW2,Destiny 2,Minecraft and Apex Legends
Other details (existing parts lists whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):  https://pcpartpicker.com/list/LgmGzf.       1440p with at least 120+ refresh rate on more competitive games and 4k 60 refresh rate on story games.
https://linustechtips.com/topic/1475586-first-build/
Way faster and cheaper, you seem to be in love with corsair.
5800X for gaming is a terrible purchase, you'd be better off with 5700X. So, I changed it with 7600X.
Better and cheaper AIO, doesn't look as good tho.
Great B650 board, 2X16GB DDR5 6000 with RGB.
2TB P3 Plus because 980 Pro is a waste of money, you won't feel the performance difference anyway.
6950 XT which is much much faster than 3080 10GB for non-RT.
4000X is a hot box, you have high powered components, I wouldn't get a case with terrible airflow.
Cheaper yet still high quality 850W Gold PSU, certainly way better value than RM850x.
P12 A-RGB fans, better value than those SP120s.
https://pcpartpicker.com/list/BgLDd9
CPU: AMD Ryzen 5 7600X 4.7 GHz 6-Core Processor  ($248.99 @ Amazon)
CPU Cooler: ARCTIC Liquid Freezer II 240 A-RGB 48.8 CFM Liquid CPU Cooler  ($111.99 @ Amazon)
Motherboard: Gigabyte B650 AORUS ELITE AX ATX AM5 Motherboard  ($229.99 @ Amazon)
Memory: G.Skill Trident Z5 Neo RGB 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  ($179.99 @ Amazon)
Storage: Crucial P3 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($124.99 @ Amazon)
Video Card: PowerColor Red Devil OC Radeon RX 6950 XT 16 GB Video Card  ($784.99 @ Amazon)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($89.99 @ Amazon)
Power Supply: Thermaltake Toughpower GF1 PE 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($124.99 @ Amazon)
Case Fan: ARCTIC P12 PST A-RGB 0dB 48.8 CFM 120 mm Fan  ($16.98 @ Amazon)
Total: $1929.88
Occassionaly visits the forum when I have nothing to do at work.
https://linustechtips.com/topic/1475586-first-build/#findComment-15712484
Total: $1929.88
This ^^ by purchasing a 5800X you'll be locking yourself to the previous-gen motherboards and chipsets with the AM4 socket. For upgrading down the line, a 7000 series CPU is by far the better option.
https://linustechtips.com/topic/1475586-first-build/#findComment-15712491
Total: $1929.88
Damn, I already got the 5800x. Could I swap out the CPU, motherboard and ram for the ones I had before?
https://linustechtips.com/topic/1475586-first-build/#findComment-15712505
I mean sure you could, but I just think that 5800X is a terrible value.
I would see if I could return them tho, because 7600x is literally the same price as 5800X, yet so much faster than 5800X.
https://www.techpowerup.com/review/amd-ryzen-5-7600x/20.html
And please don't get a 3080 for $959, that is way too much for a 3080, especially seeing as 6950 XT is so much cheaper than it. Terrible value all around.
https://linustechtips.com/topic/1475586-first-build/#findComment-15712519
